Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-17-2011, 11:08 AM   #1
Default How should i charge an 8.4 volt nimh battery 3000 mah
hey guys im new two this and a friend tells me i should know how to charge my battery so i dont loose power.
can you guys tell me how to charge A 8.4V NIMH 3000MAH battery with an onyx100 charger?
ill post pics if it helps thanks.
Organics is offline   Reply With Quote
Old 01-17-2011, 11:14 AM   #2
Default battery charging
Never go over 3 amps on a 3000 mah... I would charge it at 1.5 amp if you have the time it is a better charge but taks time
Rob-00 is offline   Reply With Quote
Old 01-17-2011, 11:17 AM   #3
how long would it take to charge at 2-3 amps?
Old 01-17-2011, 12:58 PM   #4
It will theoretically take one hour and 20 minutes to charge it on 2 amperes. And on 3 amperes, one hour. But keep it on about 1,5 amperes like Rob says.
Read more about my homeplace in New York Times (LOL)
http://www.nytimes.com/2010/11/11/world/europe/11norway.html?_r=2&scp=1&sq=hardanger&st=cse
Lars in Norway is offline   Reply With Quote
Old 01-17-2011, 01:28 PM   #5
Trader Rating: 21 (100%+)
If these are new packs, you prob should 'condition' them so you get the best from them. Take some time and read this - its the best all around guide I've run into -
http://www.camlight.com/techinfo/techtips.html
As soon as you get 8 to 10, maybe 12 cycles on the pack, I would bump charge rate to at least 3amps. I run 4000mah packs 7 cell pacs and charge mine at 5amps. A better charger would help get the most from these pacs.
Duster_360 is offline   Reply With Quote
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 05:25 PM
Platinum Lipo WorldCup2004 Electric On-Road 1192 04-24-2008 08:51 AM
The Coming Battery Wars of our Age ? Cain Electric Off-Road 52 01-19-2008 12:40 PM
