newb rc tool question
hey in the market for rc tools can you guys please list the size of the hex and screwdrivers or anyother type i will need i have b4.1 and losi strike i am pretty new to rc still learning so can list ones mostly used for those two cars
http://www.harborfreight.com/33-piec...set-93916.html
perfect saw that but wasnt sure wht size they need to be
Well, 1st step is finding out whether you need metric or SAE. Didnt your vehicles come with some allen wrenches? Can you read if it says like 2.5mm, or 3/32nd...etc?
If its metric, I suggest these
http://www.hobbypartz.com/11pcsrctokit.html
cant beat the price - and I've gotten lots of compliments on them..
Have held up very well.
Not sure if they offer this set in SAE..
I have a b4 and i believe the kept the hardware sae on the b4.1[like 99% sure] i have a .050,1/16,5/64/3/32 hex drivers... and for nut drivers i have a 11/32 and a 1/4...like i said im 99% sure they kept the hardware sae
money is tight for my hobby would that set from harbor feight do for decent set
Super Moderator
Trader Rating: 31 (100%+)
The Losi Strike also uses SAE-inch hex hardware, basically the same as a B4.1. This is an area you don't want to skrimp too much or will end up with stripped screw heads.
Dynamite makes a decent set that is fairly reasonable, and widely available. Get a better set if you can though. The machined Dynamites for example are darn good and still somewhat reasonable in cost, and there are many other good to great options from that price and up.
Don't forget the standard motor screws are metric.
Not sure what size nut drivers the Strike uses for the wheel nuts and shock mounts, but I think they are 1/4". You don't really need the best nut drivers, this is a place you can get away with something less expensive without much risk.
Hex-allens:
0.050"
1/16"
5/64"
3/32"
2.5mm
Hex-allens:
0.050"
1/16"
5/64"
3/32"
2.5mm
