Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 12-08-2010, 08:56 AM   #1
Default Brushless Setups for a 1/8 scale buggy.
Just doing some research now for a Possible Brushless Conversion for my Ofna Lx Comp. I know there are some setups that vary by the size of the vehicle (for example you can't put a 1/10 scale setup in a 1/8 scale due to the extra weight) I just want to know the ideal sized motor and voltage of batteries that would be able to power my Buggy.
Another question, what is 13.5T, 17.5T, and 8.5T when I look at this
http://www.shopatron.com/products/pr...1.1.0.0.0.0.0?
K-Train is offline   Reply With Quote
Old 12-08-2010, 09:55 AM   #2
Trader Rating: 21 (100%+)
Those are diff motors, BL motors go by turns or KV or both - discussed in here -
Explain to me the KV And Turn on Brushless Motors
As far as buggy choices, most seem to run them on 4S voltage wise, I'll let others comment on which motors might be good choice.
Duster_360 is offline   Reply With Quote
Old 12-08-2010, 08:00 PM   #3
slackomatic's Avatar
I have a ofna 1e and I am running it on mamba monster 2200kv on 4s lipo.
More than fast enough. a little to fast for a beginner like me.
slackomatic is offline   Reply With Quote
Old 12-09-2010, 06:26 AM   #4
Drop the gearing a touch, one or two fewer teeth on the pinion, make it easier to control.
Old 12-10-2010, 12:33 AM   #5
TocSin's Avatar
Trader Rating: 51 (100%+)
I run a Tekin RX8 ESC and a Tekin T8 1900kv motor in my 8ight-E 2.0 on a 4s and it's perfect for me with more than enough power to get me in trouble . This setup will handle a 6s lipo also, so I have room to grow with it.
One note, the kv rating doesn't really carry the same meaning with different sized motors. Generally, the bigger the motor, the lower the kv for similar output. i.e. a 7.5t 5500kv 1/10 scale motor on 2s has about 1/3 the power of a 1900kv 1/8 scale buggy motor on 4s.
TocSin is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18837 11-05-2017 05:29 AM
Speed Passion 1/8 scale brushless Applesauce Electric Off-Road 1000 02-28-2013 09:09 AM
1/8 scale buggy brushless setup suggestion discgolferlee Electric Off-Road 26 02-15-2011 07:32 AM
Pillow ball vs c-hub steering for 1/8 scale marine6680 Electric Off-Road 7 10-01-2009 10:55 PM
