Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 12-05-2010, 09:25 AM   #1
Default Stock slash class
I am new to racing and just bought a slash 2wd to race in the stock class, I have a quesion on batteries, the 5000 to 5500 50C lipos that I observed most guys using are $100 to 140. I dont have that kind of money to spend on batteries. Can I still be competitive using a 3000 to 4000 50C or 60C battery at half the price?
Thanks, Rick
RickV is offline   Reply With Quote
Old 12-05-2010, 09:32 AM   #2
D-Rek07's Avatar
Thanks, Rick
Well I'm not sure where you can get lipos at half that price but it would be fine if you can. Go for it.
B4.1-MMP, 10.5 Ballistic
SC10 4x4-RX8, 4.5 Tekin
D-Rek07 is offline   Reply With Quote
Old 12-05-2010, 09:36 AM   #3
I meant that the batteries with 3200 to 4000 mah 40C or 50C were close to $50 to $60 versus the 100 to 140 range.
Old 12-05-2010, 01:11 PM   #4
racer53's Avatar
one thing to keep in mind is yyour run times will be shorter as you decrease the -Mah
"Whatever can go wrong, will go wrong"...Murphy's Law...Murphy was an optimist.
/ FT RC10B4 / FT RC10T4 / Driven just about everything else /
/ Mike's Hobby Shop...Carrolton Texas /
"All short course drivers aren't hackers,but all hackers are short course drivers"
racer53 is offline   Reply With Quote
Old 12-05-2010, 04:24 PM   #5
slackomatic's Avatar
I noticed you are going to be running that slash in "STOCK CLASS". I obviously dont know what your stock rules are but a lot of stock class rules have like 17.5 BL motor regulations on them and I dont know many BL motors that need a 50-60c battery. You might could lower the C rating and get cheaper batteries.
My slash is running a novak ballistic 17.5 and I only run 2s 3700mah 25c. And I run 5min heats and 10min mains. I am able to recharge the same battery in between heats with no problem.
slackomatic is offline   Reply With Quote
Old 12-05-2010, 07:10 PM   #6
Matt Ward's Avatar
Trader Rating: 23 (100%+)
In your case I would get a 5000 mah pack with a lower c rating. Chances are you wont be able to use all of it anyways running in the stock class.
Matt Ward is offline   Reply With Quote
Old 12-05-2010, 07:31 PM   #7
http://hobbyking.com/hobbyking/store...dProduct=14327
here is a 5000mah 30c. This should run the slash in stock class no problem.
You might be able to run a little low C rating but without knowing what power plant you are using I dont want to recommend anything lower.
Old 12-05-2010, 07:58 PM   #8
HobbyKing.com for the win!!!!!!
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 12-06-2010, 08:14 AM   #9
It is the stock 12T 550 traxxas motor
Old 12-06-2010, 10:08 AM   #10
I assume you have the xl5 stock ESC. and the specs for it are.
SPECS: On Resistance Forward: 0.007 Ohms
On Resistance Reverse: 0.014 Ohms
Peak Current-Fwd/Rev: 100A/60A
Braking Current: 60A
Continous Current: 14A
BEC Voltage: 6.0V DC
BEC Current: 1A
Power Wire: 14AWG/ 5"
Input Harness Type: 26AWG/ 9"
Transistor Type: MOSFET
PWM Frequency: 1600Hz
Thermal Protection: Thermal Shutdown
Single Button Setup: Yes
Motor Limit: 15T (540 Size), 12T (550 Size)
Input Voltage: 4-8 Cells (4.8 to 9.6V DC)
Weight: 3.07oz (87g)
Says the peak current is 100A with continuous of 14A. So if you wanted to run 5000mah and 30C thats a max current draw of 150A. (30x5=150)
With that said a 20C 5000mah would be max draw of 100A which should be enough but it might heat up the battery so to be on the safe side I would run no less than 25C.And that would give you max draw of 125A on a 5000mah at 25C.( 5x25=125 )
SLASH CLASS LOVE IT HATE IT? li racer Electric Off-Road 475 05-21-2010 10:34 PM
Racing & Free Stock Slash racing Tommorow 11/8 at M&M (Houston) benben10 Texas Racing 7 05-12-2009 07:42 PM
Slash class at dalton rc lil Dalton Rc Georgia Racing 74 01-29-2009 03:02 PM
Slash Class at Dions scubajt41 Georgia Racing 63 11-27-2008 04:37 PM
