Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-28-2010, 03:45 AM   #1
Default newb question battery??
I have a 6 cell 7.2 1200mah bat, do I have to stay with a 1200mah or can I go with some thing higher like 3000mah??
fast rap is offline   Reply With Quote
Old 11-28-2010, 04:23 AM   #2
blis's Avatar
The only consideration you have to make is that Current and Voltage are relative in batteries. If you increase the current, the charged battery will produce more voltage.
For most RC cars, electric I assume, this isnt a problem.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 11-28-2010, 07:15 AM   #3
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
what are you using this battery for? I run a 3800mAh in my Tamiya's. higher mAh just means more run time ( the voltage stays 7.2v)
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 11-28-2010, 12:24 PM   #4
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by The Hawaiian View Post
what are you using this battery for? I run a 3800mAh in my Tamiya's. higher mAh just means more run time ( the voltage stays 7.2)
Just to back up The Hawaiian, he's right. At a point the cells get physically bigger and fit might be and issue but not until like 4200mah.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-28-2010, 02:38 PM   #5
Trader Rating: 21 (100%+)
As long as you can get a 6 cell pack to fit, you're good. Running 6 cells the voltage will stay the same as its been and the higher capacity (mah) will just mean a little more punch and mor run time.
Duster_360 is offline   Reply With Quote
Old 11-28-2010, 03:11 PM   #6
blis's Avatar
Put a multimeter across a charged 4000 and a 1200 and you'll see what mean.
Old 11-28-2010, 08:35 PM   #7
Super Moderator
racer1812's Avatar
I know there most likely will be a difference in voltage but not enough that it should a problem, I don't see it as an issue.
Yes i'm a newb, question about my LiPo.. punkvixen Rookie Zone 12 01-25-2010 03:05 AM
Newb question about HSN/LSN/ISS on REVO 3.3 Willystylee Monster Trucks 6 06-26-2008 03:14 PM
some battery questions Rasmus TbEvo IV Electric On-Road 25 02-11-2006 08:32 PM
Battery Care, Charging Tips, etc Jpt249 Electric On-Road 33 01-06-2004 11:37 AM
