Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-27-2010, 09:32 PM   #1
Zac_with_no_K's Avatar
Questions?? Taking off E-clips/rings?
Anyone got any good methods so they won't bend while taking them off??
Anything helps
Thanks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 11-27-2010, 11:43 PM   #2
D-Rek07's Avatar
Anything helps
Thanks.
Use a small flat-head screw driver and pry it off. That is what i normally do.
B4.1-MMP, 10.5 Ballistic
SC10 4x4-RX8, 4.5 Tekin
D-Rek07 is offline   Reply With Quote
Old 11-27-2010, 11:44 PM   #3
D-Rek07's Avatar
But be careful it doesn't spring off and you will lose it. So put your hand behind it or something else.
Old 11-27-2010, 11:56 PM   #4
Thanks!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 11-28-2010, 12:51 AM   #5
BuggyKing's Avatar
Trader Rating: 17 (100%+)
What works best for me is I use a pointed X-acto blade. Works good everytime.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 11-28-2010, 08:06 AM   #6
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
+1 I use the back side of a X-acto blade to carefully push the e-clip out then use the point to retrieve it. (looks like my next video)
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 11-28-2010, 12:20 PM   #7
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I have one small enough to fit "inside" the E part, say between a shock shaft and the e-clip.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-28-2010, 12:58 PM   #8
BrodieMan's Avatar
I use my small side cutters to grab it and pull it off or for larger e-clips I use needle nose pliers, one side on the shaft, the other side on the 'feet' of the e-clip and close the pliers. The clip than is half way off and you can pull it off with you fingers. I have owned Losi cars long enough to have a severe hatred of the e-clip
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 11-28-2010, 02:46 PM   #9
Trader Rating: 21 (100%+)
I try not to use them to start with and some of my rcs that were using them on hinge pins, I drilled and threaded for grub screws to hold the hinge pins now so they're no longer needed. But I've still got several that use them.
If I don't have spare eclips, I put the whole thing in a big ziploc bag if I can so when it pops off, it doesn't disappear, it stays in the bag. I use a jeweler's flat bladed screwdriver to coax them off. Just get in one of the spaces an pry up slightly.
Don't really care for them either.
Duster_360 is offline   Reply With Quote
Old 11-28-2010, 02:54 PM   #10
I totally agree w/Duster; I can't stand those e-clips! Check w/ www.STRC.com and see if they have bolts w/nuts for your application.
bowl806 is offline   Reply With Quote
Old 11-28-2010, 04:17 PM   #11
What i do when prying them off is to have a little dab of grease on them, it is a bigger chance to find them if they takes off then! They will stick to something on its way, and the floor don't like to eat these clips with grease on -only the ones without grease
Read more about my homeplace in New York Times (LOL)
http://www.nytimes.com/2010/11/11/world/europe/11norway.html?_r=2&scp=1&sq=hardanger&st=cse
Lars in Norway is offline   Reply With Quote
Old 11-28-2010, 05:00 PM   #12
Wow, thanks everyone for all these different methods!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 11-28-2010, 05:27 PM   #13
I like to find the most fluffy shop towel around and wrap it around the clip in question before prying and it usually catches it.
burnineyes is offline   Reply With Quote
Old 11-28-2010, 06:08 PM   #14
bluechucky's Avatar
I use an e-clip removal and insertion tool like this.
http://www.liquidrc.com/index.php?ma...ducts_id=13561
B4 FT, B44 FT, SC10 FT
Powered by Novak and Fantom Motors, Spektrum Radios, Savox Servos, Intellect Batteries, JConcepts Wheels and Tyres.
Proud member of Keilor Electric Off-Road Car Association.
bluechucky is offline   Reply With Quote
Old 11-28-2010, 07:03 PM   #15
I have an E-clip tool that looks more like pliers, but i don't know if it takes them off. Haven't used it in about 5 or 6 years
TA05v.II
Tamiya M-05
SC10 Brushless RTR
