Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 10-26-2010, 11:52 PM   #1
aiyoaiya's Avatar
Default shocks and springs
hi guys and gals, got a silly question here but wondering if anyone out there remove the shocks and springs of your offroads if were to store for months??? will it do any harm if u dun??
WiCkeD RaCinG TeaM
HPI Savage X 4.6 RDLogics Exhaust
Thunder Tiger ST-1 Alpha .23 Jammin JP-3
Xray 808 AxeMotorRossi .21 Mamba Jammin JP-1
Serpent S960 GRP .21
aiyoaiya is offline   Reply With Quote
Old 10-27-2010, 01:13 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Shocks don't mind if they sit, but springs actually do. If you let a spring sit loaded for enough time it'll refuse to return to it's original length, so you'll lose a bit of preload. Springs do wear out as well, even if you take the utmost care of them they are made of metal, and all metal (heck, any solid material) will fatigue over time.
Fully removing the springs from the truck might be a bit overkill, but when you park the truck, sit the chassis up on blocks or a stand or something and let the tires hang. That'll keep your springs in shape. It's good for the tires as well, leaving them sit in one place long enough will put a flat spot on the foam inserts
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 10-27-2010, 06:34 AM   #3
hyperguy's Avatar
Trader Rating: 22 (100%+)
+1
very well put!!!!!
Team Associated B5m
Team Associated B5m
Team Durango DESC210
hyperguy is offline   Reply With Quote
Old 10-27-2010, 06:50 PM   #4
Super Moderator
Yep, all of my rides sit on the chassis. Reduces oil pressure in the shocks a little too, helps reduce leaking. The tires themselves will flat spot a little as well as the foams. Nothing fancy required, an old box, old set of tires, etc.
Dave H is offline   Reply With Quote
Old 10-27-2010, 10:11 PM   #5
aiyoaiya's Avatar
ah... learn something new everyday... my rides been sitting there without blocks or stands over 6 mths already thanks guys
WiCkeD RaCinG TeaM
Old 10-27-2010, 10:26 PM   #6
Even if you notice a flat spot in the foams when you pick the truck up, majority of the time a run or two will "pull" them back into shape. Just try not to do it too often
Faster Than Factory
Old 11-02-2010, 05:46 PM   #7
aiyoaiya's Avatar
does this apply to onroads as well?
WiCkeD RaCinG TeaM
Old 11-02-2010, 06:35 PM   #8
Trader Rating: 21 (100%+)
Yes, I do it with all my RCs onroad or offroad, they sit on the chassis, not the wheels.
Duster_360 is offline   Reply With Quote
Old 11-02-2010, 08:57 PM   #9
just for example...... the clutch spring inside of a snowmobile or atv is compressed from 5 inshes (ish) to under two (fully coil bound) hundreds of times per day during a good ride...after a couple months of hard riding your rpms get outa wack and you pull the spring out and find it over an inch shorter and considerable softer rate if you test it.....so yes dont let them sit loaded for a long time
More power than brains!
associated tc4
associated t4
associated 10L3
ummm...go fast?
nitrofreak07 is offline   Reply With Quote
Old 11-03-2010, 04:31 PM   #10
aiyoaiya's Avatar
got it! thanks guys...
WiCkeD RaCinG TeaM
TRAXXAS SLASH SHOCKS AND SPRINGS srracing R/C Items: For Sale/Trade 10 11-04-2009 06:55 PM
TEAM ASSOCIATED rc8 threaded shocks and springs advanaw11 R/C Items: For Sale/Trade 6 06-28-2009 11:28 AM
