19t Motor
19t Motor
I have an Epic 19 turn motor that I would like to rebuild. The catch is, I have never rebuilt a motor before. I am planning on turning the comm and replacing the brushes and was wanting to get some direction on how to do this so i did not ruin my motor.
Thanks in advance.
Thanks in advance.
It's really very simple. Take off the springs and pull the brushes out of the endbell hoods. Then unscrew the screws in between the + and - hoods then take the endbell off the motor. *Don't loose any shims* and make sure you remember which end of the motor they went on. Take the arm out and true it on a comm lathe(till it's perfectly round). Clean everything with motor spray till all the gunk is gone and then put it all back together. Whenever you cut the comm, replace the brushes if you have more then a few runs on them. If I have 4-5 runs on my brushes I re-use them if they are in good shape, I usually do 8 runs max on a set of brushes and cut every 4 runs(for racing).
An alignment tool isn't absolutely needed, but they do guarantee that the brush hoods are straight. I have the PSE tool, and it seems to work. Before buying that, I advise buying a brush serrator and/or cutter, and a timing jig. I use a Racetech serrator, it's cheap and does the job, and a Racetech timing jig. Another good buy is the RPM motor stand, it's just VERY handy.
Originally posted by crashnburn
Or buy a brushless system. Then you don't have to worry about all that stuff!
Yep, same but different.
Brushless isn't Roar legal till 2005...
Motor Breakin
I know brushless would be easier. But, the fun is working on the car. I enjoy doing the tweaking and motor rebuilding to see if I can reduce my laptime.
What needs to be done, if anything, after the motor is rebuilt? Is there a break in procedure?
Run in(no load) at 2v for 2 minutes then check the brushes. If the whole face of the brush shows wear then it's run in, if not, keep going till it's run in. If you don't have a 2v power source just run it in while it's in your car *take the pinion off*, set the trim so it's just spinning.
