Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 09-05-2010, 05:18 PM   #1
Robert421's Avatar
Questions?? How to locate and drill holes in a lexan body
Hi all, I have two new bodies that look great. That said, I have to cut them out, cut out the wheels, mount the wing and finally mount the body to the car. I have the body cut out and the wheels went ok with just a few misques Now I am trying to punch the holes to mount the body to the chassis. What is the best way to do this? I do not want to mess up the body anymore than I already have, but I am lost. The car and body are a 190mm touring car. thanks for any help.
Associated TC4 stock
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Robert421 is offline   Reply With Quote
Old 09-05-2010, 05:32 PM   #2
Potoczak's Avatar
Trader Rating: 111 (100%+)
YOu should always do your drilling and cutting before you paint your body's, i do that every time and they come out perfect. All though Stormer hobbies has little cups that slide over the body posts that have little LED's in them that shine through the paint, they work really well also..
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-05-2010, 05:35 PM   #3
Trader Rating: 517 (100%+)
Or may try a little tape on the body in the general area of the post hole, then a dab of paint or sharpie on the post-carefully set the body in position ( may take few tries) and the paint/marker should transfer to the tape....
flame56mx is offline   Reply With Quote
Old 09-05-2010, 05:58 PM   #4
WhoIsShaun's Avatar
The holes are almost always marked with a small groove. Simply take a flash light or a bright light and hold the body slanted against the light and you will see those grooves.
WhoIsShaun is offline   Reply With Quote
Old 09-05-2010, 06:00 PM   #5
Robert421's Avatar
delete
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 09-05-2010, 06:02 PM   #6
Robert421's Avatar
That sounds like a good idea, I'll give it a shot, Thanks
Today 04:58 PM
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 09-06-2010, 08:53 AM   #7
Trader Rating: 21 (100%+)
I always mark mine before painting the shell. But in case you don't have the chance, we have a glass coffe table and putting the rc on the table with a light underneath makes it easier to see what you're doing and get the holes spotted in the right place right.
Duster_360 is offline   Reply With Quote
Old 09-06-2010, 09:02 AM   #8
TeamSkunkwerks's Avatar
Trader Rating: 91 (100%+)
Lay the body down on a flat surface, roof side down. Flip the car (truck, whatever) over & onto the body using the body posts to support it. Line everything up the way you want to. Then mark from the insides where the body posts are & drill!! Doesn't matter if the body is painted or not-still works great!!
TeamSkunkwerks is offline   Reply With Quote
Old 09-06-2010, 01:17 PM   #9
Robert421's Avatar
I did not have the luxury of marking the holes and wheels because I had a gentleman paint the bodies for me. The process is coming along nicely and I appreciate all the input.
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 09-07-2010, 03:50 PM   #10
Trader Rating: 22 (100%+)
what i did when i messed up and painted first was take the stock body or one that is already drilled and laid it on the outside and stuck a marker inside the drilled hole and marked the new body. when you remove the body, you have 4 holes that's marked.
Brenda is offline   Reply With Quote
Old 09-07-2010, 04:32 PM   #11
Robert421's Avatar
Thumbs up
Brenda, This is a new chassis, it has never had a body on it. That sounds like a good idea that I may try in the future, thanks.
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 09-10-2010, 10:48 PM   #12
Pop35eye's Avatar
The best way is to MARK the holes with a sharpie on the protective film while the car is clear.
Then AFTER painting, before you pull the plastic film off, drill them. B.E.A.utiful.......
"Ok, Mr. 2 time Grand-Prix, 5-time WRL, future Hall-of-Fame... teach me something."
- Speed Racer.
"Hells Corner RC Club (AZ)"
Pop35eye is offline   Reply With Quote
Old 09-12-2010, 09:21 AM   #13
Robert421's Avatar
Thumbs up
I used this method and it worked great. I could say that I have learned my lesson about cutting the holes before painting the body, but I do not paint my own bodies. Thanks for all the help, Bob
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 09-12-2010, 10:50 AM   #14
Potoczak's Avatar
Thats exactly what i do!!
Pete Potoczak
Old 09-21-2010, 06:47 PM   #15
bluntsrus's Avatar
body reamers work THE BEST!
~FT TC5~FT RC10T4
Novak/Speed Passion/Trinity/LRP/Futaba/Spektrum/Turnigy/Reedy
Fantasy World Racing Tacoma,WA. !*253*! Corona!
bluntsrus is offline   Reply With Quote
