MX-3 Plus and Idiot = No Reverse
Call me an Idiot, I just picked up an E-maxx with a MX-3 radio and reciever, the darn thing doesn't go in reverse.... does it? And if it does, how do I change it? Not a Newbie, but puzzled..
Thanks!
M@
Thanks!
M@
it should go in reverse, try the 3rd channel, or even recalibrating teh esc. Radio trims? make sure they are all adujested right
I believe your supposed to push the lil auxiliary button down
Yeah the esc should allow the truck to go in reverse by applying and holding the trigger in the brake position. If you use the 3rd channel button, the truck should shift into second gear.
It's quite different from the nitro T-maxx version. You may also need to program the esc to the radio if it hasn't already been done.
