car wont stay running
well i broke-in my Jammin X1x its the RTR version idk what engine that is but i printed out some tuning tip pages and tryed to tune it we had it going for a little bit but then it seem right so i messed with it and changed glow plugs and made sure my glow plugs starter worked and now it runs when i have my glow plug start in but when i take it off 5 secs after it just dies out, any tips on what i could of done wrong or if theres a factory settings for the needles that i can do or something
running with the igniter still attached, take it off and it dies, i`d say ur
glow plug is stuffed,if it continues to do this after glowplug replacement,
i would say that it would be too rich down low(LSN), also make sure
ya have atleast a 1mm gap between ur carby slide and the throat of
carby,generally if ya lean ur(LSN-throttle servo side on carby slide)
this will increase ur idle speed, as for needle settings, surely they
would be in ur instruction manual, if car is an RTR..Hope this helps..
ok thanks i looked in the book and the book they sent me with that thing wasnt rly a book it was printed papers of like the parts list and every thing but i looked threw it 3 times and it didnt say nuthing about the needle settings , and ill change the glow plug and do the 1mm thing and see what happens thanks again
