Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 12-04-2009, 06:17 PM   #1
magnificent_1's Avatar
Default Battery........... dead again!!
Hi all,
It seems problems keep on coming for my truck,or maybe i'm just being paranoid.Just when i think my servos problem are over,now came with the receiver battery.
a) The power remains low even i have charged my battery for a solid 2 days!
b) Try to switch to a peak detection charger but still fails
c) Has my battery runs out?
d)Is it got something to do with my ON/OFF switch?Cos there's one particular moment that i accidentally connect the battery wrongly and the switch cable melted just abit,but even after that, connection seems normal.
FYI,im using Team Orion 1600 Mh and Prolux TX-RX charger.
Pls advice...thanks in advance!
magnificent_1 is offline   Reply With Quote
Old 12-04-2009, 08:31 PM   #2
Toh WL's Avatar
btw your rx is using LiPo or NiMH. That does make a difference if shorted.
besides that you can loan another battery from your friend to accertain the fault too.
Toh WL is offline   Reply With Quote
Old 12-05-2009, 07:24 AM   #3
Trader Rating: 21 (100%+)
Peak charingwill give you a better charge for a NiMh rx pack. If the charger shuts down quickly, its prob false peaking and you need to reset it and try again. False peaks can be common and you may need to reset it several times. The pack should get pretty warm if its is charging correctly. NiMh peask at like temps of 120-130F.
Make sure when youi reverse connected it and partially melted teh wiring that you have damaged the wiring. This switch may be damaged and part or all of the prob.
Duster_360 is offline   Reply With Quote
Damnit, the lipo battery industry needs better standards! Freezebyte Electric Off-Road 130 06-20-2017 10:07 AM
Let the battery wars begin "AGAIN" Cammer Electric On-Road 84 01-04-2010 04:29 PM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 02:07 AM
Nicad battery "fix" or repair..... y2kgtp Radio and Electronics 8 12-30-2008 11:46 AM
HKSdrifter sell me a dead IB4200 hughlim Singapore R/C Racers 65 01-16-2008 12:24 AM
a123 battery packs party_wagon Electric Off-Road 81 11-30-2007 09:38 PM
Intellect Battery 3800 rayhuang Electric On-Road 1166 05-30-2006 06:51 PM
