Futaba 3PK
Old 11-25-2009, 11:42 PM
Default Futaba 3PK
I have had a few problems recently with my 3PK losing sync and the fail safe is not working. Just found out that my receiver is set to PCM and that there is no fail safe features with that mode. I just changed it to HRS and am now able to set the fail to close the carb if it loses sync. Tested it and it seems to work perfectly I am using a R603FS receiver. Is this the correct setting or should it be PPM?
Ryans150 is offline
Old 11-26-2009, 07:41 AM
Trader Rating: 21 (100%+)
You should on use HRS mode if you have digital servos. Otherwise you use PPM if they are not digital. You can still use the failsafe in PPM but you have to set it everytime you power up the reciever. It is easier to just use a throttle return spring.
VA_Racer is offline
Old 11-26-2009, 09:37 AM
Default Futaba 3PK
I use Hitech 7955TG Servos and I just set it to HRS.
Ryans150 is offline
Old 11-26-2009, 10:07 AM
tc5 man's Avatar
dont u have to use the speckum hrs module though if u use hrs mode for the dingal servos ,i have the orignal gray module speckum with the dignal servos and use ppm and they seem pretty fast,i have my fail safe set with the ppm just set it to half throttle brake not full it will hurt your servo if something happens
tc5 man is offline
Old 11-30-2009, 10:21 AM
I use the R603FS and I thought it was HRS compatible. I set the 3PK for HRS and everything seems fine.
Ryans150 is offline
Old 11-30-2009, 10:22 AM
Does anyone use the ABS feature on the 3PK. Just trying to figure out if it is worth setting up.
Ryans150 is offline
Old 11-30-2009, 05:23 PM
tc5 man's Avatar
yea i was trying to get the abs brakes on my 3pk to work it woulnt do anything for some reason
tc5 man is offline
Old 11-30-2009, 09:57 PM
Great.....now i know im not the only one having problems with the ABS feature
Ryans150 is offline
