Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-24-2009, 02:01 PM   #1
Default Glow Plugs
Now that it is almost winter and the temps are much cooler outside. Do I need to go to a hotter glow plug. I run a RB C6L2G with a Rb#6 plug.
Ryans150 is offline   Reply With Quote
Old 11-25-2009, 07:50 AM   #2
Trader Rating: 21 (100%+)
I would only charge if you're noticing probs with idle where there were none in warmer weather or a noticeable drop in rpm when you remove the plug heater.
Duster_360 is offline   Reply With Quote
Old 11-25-2009, 11:08 AM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
6 is a good plug for that motor in most conditions. A 5 can really help idle and give a more crisp throttle response if the weather gets really chilly.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-25-2009, 09:18 PM   #4
Questions??
Thanks, I just bought a bunch of Novo C5 plugs. I'll give them a try this weekend and let you know what happens.
Old 11-25-2009, 10:14 PM   #5
tc5 man's Avatar
yea defiely when it gets cold outside you want a #5 nova plug they might be a little more money but they last pretty long even after break in they are good and also rich your top end neddle a bit also if its like 30 degress or 40
Old 11-26-2009, 09:40 AM   #6
Default Glow Plugs
The last time I ran the car it was around 80 degrees outside with the #6 plug. The temperature has now dropped into the mid 40's so I'll put the hotter plug #5 in and see how it works. It usually doesn't drop under 40 degrees here in CA so hopefully this setup will work fine.
Thanks for the responces.
