Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-22-2009, 02:56 PM   #1
Default differential problems?
I'm just wondering what are some of the symptoms of a bad differential on your nitro RC. When do you know it's time to take your car apart and check them? thanks for any info.
RCs=Revo,SC10,Slayer[roller],Blitz,miniRevo
2k7bkr is offline   Reply With Quote
Old 11-22-2009, 04:10 PM   #2
rccar306109's Avatar
Send a message via AIM to rccar306109
It's hard to tell with a nitro since it's loud. But when you hit the gas hard on a high traction surface it will make a strange sound. Like a loud duck quaking.
Driver of the #18 Toyota Scion of Scranton Camry Late Model at Mountain Speedway.
Special thanks to:Toyota Scion of Scranton, Coldwell Banker Town and Country, AMSOIL, Six Feet Deep Clothing, and Myifixer. RACE 101 Scholarship Recipient. Want to sponsor a professional race team? PM me for a proposal!
rccar306109 is offline   Reply With Quote
Old 11-22-2009, 04:25 PM   #3
stoney1974's Avatar
Trader Rating: 11 (92%+)
i change fluid in mine after about 3-5 race weekends
drive fast take chances
www.askrcracing.webs.com
crazy traction compound
stoney1974 is offline   Reply With Quote
Old 11-22-2009, 04:32 PM   #4
Trader Rating: 21 (100%+)
SOme of this depends on whats going bad inside the diff.
I know mine have usually started with a clicking noise, particularly noticeable when you let off the gas. As it got worse, it grew to a grinding noise which was when I pulled it - was the spyder gears - one had failed.
Other probs I've had - striped ring gear - teeth literally torn off the ring gear - would see funny accel, jerky almost and eventually get the grinding noise.
Anything looks wrong - pulling to one side on accel, jerky accel, strange noises (clicking or grinding) its time to pull and see whats going on.
Duster_360 is offline   Reply With Quote
Old 11-23-2009, 10:05 AM   #5
Suspended
Trader Rating: 2 (75%+)
"checking the diffs" is part of the routine maintenance on any nitro.
if you let them go until it sounds bad, then you have to replace the entire works.
justanotherdude is offline   Reply With Quote
