Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-22-2009, 08:45 AM   #1
Trader Rating: 42 (100%+)
Default tekin redline timing?
look at the pic guys is this zero timing.. and if you can guide me to any thing that explains this thank you.
Team Radiopost-SMC Racing-R1wurks-Savox-AKA
XB2ce
BIGTRUX is offline   Reply With Quote
Old 11-22-2009, 10:18 PM   #2
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
CAnt tell from that picture, but it looks close to zero. If you look on the can (not the endbell) there is a little sticker with the timing notches listed there. The notch on the endbell lines up... and that is how you lign up the timing.
If I remember right, if you spin the endbell all the way to the right (while looking at it like your picture) is 0, all the way to the left is 24.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-23-2009, 06:01 PM   #3
Trader Rating: 520 (100%+)
Yep, what the Capt said sounds right, usually they come set around 12 or so..
flame56mx is offline   Reply With Quote
Old 11-27-2009, 09:18 PM   #4
Brenos's Avatar
All you have to do is loosen the 3 hex screws a bit, dont take them out.
Then you can rotate the Black end seal cap. Twisting it clock ways lowers your timing, anti clock ways increases your timing.
So twisting it clock ways, all the way will put you at 0 timing
Kyosho Lazer ZX-5 FS-2 SP, Orion R10 Pro, Team Orion VST Pro 6.5T,
Kyosho RB5 SP2 WC, Tekin RS Pro, LRP X12 10.5T
Brenos is offline   Reply With Quote
