Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 11-20-2009, 11:57 PM   #1
Default question abt Droop setting
Hi,
currently i am running 1:10 scale rc car.
but i am confuss abt this droop setting thing.
i know tat increasing droop for 1 end is for the other end's gripness,
example increasing droop for my front means my rear will get more grip.
is tat true? cos currently i do not feel it tat way.
can some1 plz explain it clearly wad droop is all abt in DETAILS?
thks alot!
cheers.
carpentor is offline   Reply With Quote
Old 11-21-2009, 08:38 AM   #2
Trader Rating: 21 (100%+)
Download the T2 Setup book here and go to pg 10 - its explained in detail.
http://www.teamxray.com/teamxray/pro...5e4c4f85a7bfdd
Duster_360 is offline   Reply With Quote
Old 11-26-2009, 09:40 PM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
ur question seems to be difficult to understand. Are you referring to droop and cornering on and off power.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 11-26-2009, 09:49 PM   #4
Razathorn's Avatar
Sounds like you're confusing droop with ride height. Droop is how far down your suspension travels at maximum -- like with the car held in the air. Makes a difference how the car lands on jumps and can also affect things in hard cornering by limiting suspension travel to prevent roll. Ride height is something very different -- how high the front or rear of the car sits off the ground at rest. Raising/lowering the height at one end will remove/add grip at that end in a corner -- this is due to the fact that you're changing the roll axis of the car by raising or lowering the roll center at a given end by changing the ride height.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
