Originally Posted by B4power
Try buying a new antenna tube that you can find a your lhs. If that doesn't fix your problem then it could be that your receiver is no good and you will need a new one.
It's not the antenna tube. This kind of thing can happen for all sorts of reasons.
1) antenna touching the graphite chassis
fix = rerun the antenna so it's not touching anything but the plastic holder and tube
2) fautly esc.
fix = find a different esc to use temporarily. If the problem goes away, you found the cuprit
3) faulty receiver or crystal set
fix = borrow or use another radio and recevier set, and see if the problem goes away.
4) somebody on your frequency. try a different set of crystals, see if the problem goes away.
