how to get tc4 to handel better
Give us a little more information on what kind surface you'er racing on, and track length.
When bashing with a tc4 the simplest things you can do to make it attempt to handle are
1. buy some foam tires, something in a medium compound
2. set the shock springs very light and remove any sway bars.
the foams with some traction compound will offer better grip than any rubber tire and the for some crazy reason tc4's like to have a soft suspension with a lot of body roll. Hope this helps as a starting point.
A 4.5 motor, in a TC4 is going to make a lot of problems for you. Torgue steer, alone, will make handling an issue. Not to mention, the amount of force you'er putting on the ball diffs and overdrives.
I don't know any setups for a modified TC4, but you'er going to need a lot of everything, to get it to track steight.
You won't totaly be able to ride torgue steer. It's a part of the car, and it only gets worse when you get it to higher speeds. You could start by getting some high dergee caster blocks. And bring down your ride height as low as you can get it, without bottoming out.
