temps and gearing
temps and gearing
ive been reading about people needing to change gearing due to temps? I guess my question is how do i know if my gearing is set correctly.
I have a bone stock Slash running a 5000 mah venom battery. After the run my battery is hot (can hold for 3 sec) the esc is barely warm. and the motor is a lil cooler than the battery. my truck runs 16.6mph (GPS) and the battery last 15min.
I guess the same question for charging. i have 3 settings for the charger. 2\3.5\5 amps. When should i charge on what and what does the temp tell me?
Also i just bought a 3600mah 8 cell battery. how should that differ from the venom?
Thanks in advance
Thanks in advance
Id Charge your venom at 5amps and your new battery at 3.5amps. Runtime should be higher on the venom. How many cells is it?
As for gearing a larger pinion(small gear) will give you more top speed but your stuff will run hotter with less run time. A smaller pinion will give less speed but more torque it will have more run time as stay cooler. The spur gear(big gear) is different for more speed get a smaller one. For less speed more torque get a bigger one.
Super Moderator
Trader Rating: 31 (100%+)
With an 8 cell pack your motor heat problems are only going to get worse unless you put a smaller pinion on it.
Suspended
so i think i know the answer to this,, but is this too hot? i charged it at 5A and left for work, when i came home. wahlah. goood thing that wasnt my new battery. as for my new battery, MAN i dont even want brushless with this thing. . Im sure its not the greatest but its good enough for me. I have to learn throttle control. If i go down in pinion, does that mean its gonna have more torque? or does the motor just spin faster?
[QUOTE=wheremiat;5914343]so i think i know the answer to this,, but is this too hot? i charged it at 5A and left for work, when i came home. wahlah. goood thing that wasnt my new battery. as for my new battery, MAN i dont even want brushless with this thing. . Im sure its not the greatest but its good enough for me. I have to learn throttle control. If i go down in pinion, does that mean its gonna have more torque? or does the motor just spin faster?[/QUOTE
the 5 amps thing is fine but u never leave a battry un attened
Def got too hot - you really shouldn't be leaving the batt on charger and going off, thats not safe practice, you could easily have a fire. Plus if you monitor batt while charging, you can tell its getting too hot and stop the charge potentially saving the batt. You dont have to be there every sec, but check on it while charging every few minutes.
Down on th epinion - more torque, less speed. No motor won't spin any faster since speed goes down.
5a should be ok, but new batts can get real hot - monitor batt when charging - if batt gets too hot to hold comfortably, back off charge rate a little to 4amps.
Then a cell (or two) prob went bad in that pac - when cells go bad, the internal resistance goes way up and they get very hot when charging - hot enough to vent and peel shrink off the pac. The pac was most likely done anyway. You may be able to salvage a few cells if they have any use to you for potential replacement cells when the next one goes bad.
I use a thick porcelain plate I charge batts on so if something happens, it doesn't harm anything, hope you didn't scorch anything too bad.
you might be right about one cell going bad. the paper around one cell is darker than the others as if it leaked. and nothing was harmed, i charged it in the middle of the garage floor. i dont bring any of my rc stuff inside the house. thanks for the tips and i told ya so's. now im gonna play with that pinion.
