CONVERTING TO LIPO
CONVERTING TO LIPO
WHAT ALL IS NEEDED TO CONVERT AN RC 18 T TO LIPO DO I HAVE TO RUN A BRUSHLESS ESC & MOTOR... IM NEW
WHAT ESC COMES STOCK ON A RTR RC18T
"RC-18T RTR - Speed Control: Associated XPS micro size with reverse". See also -
http://www.rc10.com/shusting/CatalogHub/li-poly.htm
Super Moderator
Trader Rating: 31 (100%+)
Hey Duster, That to me says that AE is covering their butt, which they should, in the fact that the esc has no lipo cut-off. They know that most RTR are going to be used for bashing and the chance of running a lipo too low is more possible. I would think you could run a lipo but at your own risk.
Losi says the same thing about the esc in the 1/10 Slider (no lipo) I've run mine on a lipo and it's fine just no built-in cut-off.
Thats same take I had on it, its doable, but typical brushless esc with no voltage cutoff.
Smart stop should provide an lvc unless there's something going on like with a Slashes stock esc.
I'd convert it to brushless anyway. All my 18ths are converted - only one of my rtrs was ever run as brushed, rest were converted as soon as I took them out of the box.
Super Moderator
first part of your question: no you don't have to run brushless to run lipo. Brushless is better though. You can run brushless without lipos too.
