gear shift timing (kyosho FW-06)
i recently bought an fw-06 and about to adjust the gear shft timing.however, i lost its default settings.can u pls give advice on how to get a new reference point ..?
Is it the 2speed with 2 screws to adjust?
If so, from memory, I think the starting (default) point was 4 turns out.
Then depending on your eng. make fine adjustments from there, be sure to adjust both screws the same
