losi .6 buggy shocks
hey guys, i want to try out a set as they were suggeested for me to try. my question is which shocks are the losi .6 buggy shocks? are they used on the xxx-4 or the 8ight? i'm not a losi-guy, so i have no clue. also, where can i buy a set of four w/ springs? thanks in advance.
I’m not aware of Losi selling the shocks complete, you may have to buy the parts. Note that .6 (inch) can refer to both the shock body length as well as the shaft length. Also available in .9, 1, 1.2 lengths I believe, maybe others. Sometimes the bodies and shafts get mixed for various vehicles. The .6 set are used on the front of the current XXX CR buggy, not sure where else.
The .6 shaft and body: (this shows the Nitride shaft, you may be able to find the unplated shaft considerably cheaper)
http://www.losi.com/Search/Default.aspx?SearchTerm=.6"%20shock
For piecing together a set either refer to the online manual or a local shop should be able to help.
ok, thanks guys, u were a great help!
