For hpi micro speed 300
What to pinion gear?
Also what type of pinion do I use because hpi steel 11tooth pinion does not fit on graper speed 300 motor shaft.
Do I shave down the motor shaft?
Also Team Orion sells derlin pinion gears in all sizes for the micro you could pick up a pack of those.
Thanks guys!
Got it to fit and I had to really dremel down on the gear case.
I got a 11tooth on it good enough for the track by me.
thanks again guys.
thanks again guys.
