Go Back   R/C Tech Forums > General Forums > Rookie Zone
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-20-2008, 02:40 AM   #1
Ageofdeath10's Avatar
Default Steering help
With my truck i replaced the steering servo.It had failed. When it came to steering it worked about five times round and round but then it slipped off the servo. Any ideas.
Practice makes perfect..... But nobody's perfect...... so why practice?
Flash 1/10 stadium truggy
Tamiya tt-01
Ageofdeath10 is offline   Reply With Quote
Old 08-20-2008, 04:12 AM   #2
Trader Rating: 15 (100%+)
If you're talking about the servo arm that connect the servo and strg linkage, there is supposed to be a screw that connects the servo arm to the servo. That screw needs to be tight - lock washer and or medium loctite (blue).
If the screw loosens, the servo arm can move up and off the servo drive or the sevro arm can totally fall off if the screw comes completely out. Be sure and center the strg servo when you put it back together.
Duster_360 is online now   Reply With Quote
Old 08-20-2008, 02:57 PM   #3
Brandon A's Avatar
I'm not 100% sure what u mean but if you replaced the servo with a different brand you may have an incorrect servo horn on it. Also is it possible that the horn was stripped to begin with? You may want to check and make sure all the teeth inside are still there.
MRC/Team Academy <> Team TEKIN <> Panther <> Wheels Wings-N-Hobbies
Brandon A is offline   Reply With Quote
Old 08-20-2008, 03:17 PM   #4
When you changed the servo - does the servo arm have a plastic piece that fits into the arm where the arm fits on the servo? This little piece may not be right for the new servo and if not, it strips in short order. There are different numbers of splines on the servo output shaft and you have to use the right one for your servo.
Old 08-20-2008, 03:19 PM   #5
jag5508's Avatar
Depending on what servo saver or horn you might have left an insert from it on the old servo.
jag5508 is offline   Reply With Quote
Old 08-21-2008, 03:07 AM   #6
its the screw that came off thanks guys
Tamiya tt-01
Old 08-21-2008, 03:55 AM   #7
Simple enough, lol.......
Forum Jump
8T 2.0 polarismaster Nitro Off-Road 5090 Today 12:00 PM
kyosho electric offroad b-man777 Electric Off-Road 8867 11-18-2009 05:45 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 20727 11-16-2009 08:17 PM
Kyosho V-ONE RRR Evo boy2rc Nitro On-Road 3191 09-23-2009 12:40 AM
Back into R/C! Just bought a Losi Mini-T! Need help! Jongrill Micro and Mini Scales 10 05-18-2009 06:15 PM
Trasmitter Set up for new Driver imjonah Electric On-Road 16 01-31-2004 08:44 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
