Hudy????
Hudy????
I was wondering if hudy setup boards can be used to set up the TB Evo3???
What are people experience with hudy?
Wheres the best place to buy one?
yes
I would also look at the Integy set up system,It cost less,comes with a case,and is made of aluminum.I had a Hudy set up system,sold it and bought the Integy set up system because it is alot easier to see the marks and it's made of aluminum,they also have a real nice tweak board.
Set-up systems
Any websites that show me the Integy set up system???
is this the Integy setup system ???
OR is
this the 1/10 setup system ???
cheers
How does it compare with the hudy? Exactly the same but cheaper???
Does it work with Tamyia? or does it need a few holes extra (drilling)
OR is
cheers
Do you really need the metric axle nuts with the Integy setup tools? The Hudy just uses the regular axel nuts.
Just curious
Just curious
The ones that come with the Integy are a knurled type nut. Tighten with your fingers instead of a wrench like with the Hudy. Having had both I prefer the Hudy. Seems to be a lot more accurate to me. Excellent quality as well.
Later,
Later,
