Any suggestions?
#16
Originally posted by Im2lazy
Traxxasdude, nothing to insult, but have you driven a 2wd onroad car and compared it to a touring car? If you haven't had the opportunity (as most people haven't had the chance either), I'll make a pretty good example that quite easily shows the performance advatage of 4wd in RC cars:
he doesn't want a 4wd because (I think) if something gets stuck inside it you have to take apart the chassis, but on a simple f1 you don't have as much problems with matinance.
#17
Yes, that's it exactly.
I want as little chance as possible of something breaking. With a 4WD car, the chances are almost doubled.
Plus, I'm not used to having that much traction on turns cause of my buggy so would it be that much different?
#18
a 2wd on-road car has faster sininp tires usually so they break free if you just flor it.
#19
Well if you want something that is basically bomb proof and you can get RTR then look at the Tamiya XB line up. You have to go to great lengths to break a TL01 and for $200 RTR it's a good deal.
#20
Thats exactly what I have and I not such a fan of it, btw there is a week spot on the tl-01, the place where the grub screw goes in the pinion gear strips easily.
#21
Like I said somewhere else, the motor heat is the only contributor to that problem. Keep a motor like a stock motor, or a 19 turn motor with relatively little advanced timing, and give it a break between packs and it should be fine. I've driven one off-road (rally), and it took the abuse.
oh yeah, there is a big difference between a two-wheel drive truck and two-wheel drive onroad car.
C3pacer,
quite frankly, most of the 2 wheel drive cars I have seen are quite brittle. The rear pod is only held in three spots by screws, and canbe shorn straight off if you clip the rear wheels on something. But Duratrax does have that stress-tech 6month parts guarantee.
C3pacer,
#22
If your worried about breaking,your looking at the wrong car,A arms are a problem with this car,very thin,looks scale but they are a problem,Have you looked at the Traxxas 4 Tec ? It does not fit your 2wd only but 4wd does not break any more than 2wd does and your really limiting your choices for an on road car,For "bashing" it's real hard to beat a traxxas,I have had one and for parking lot or street it was alot of fun,I never had any problems with the drive train..yes I did break a few parts here and their..curb's dont give.. ,I now have a few "racing" TCs that I dont use on the street(dont want to scrach up the chassis)I think the 4 Tech is a better car for what you want to do..but the Delphi is cool looking. BTW my LHS quit carring the Delphi, to many people were bringing them back..broken wanting them fixed for free or their money back.
#23
I looked at the TL-01 cars from Tamiya and the Traxxas 4-Tec but they both have mechanical speed controllers.
Aren't they slower, less-efficient, and you have to replace them every 3 or 4 months???
Hey, but I did find this TT-01 car. It looks pretty good, fairly simple, but what is a combined reciever/electronic speed controller???
Have any of you had experience w/this car or know anything about its durability cause that is my #1 concern.
Thanks for all the ideas so far and I'm starting to become swayed from the Delphi.
#24
a mechanical speed control is great just for driving around, but yes you will nedd to replace it. When you replace it though you can just get an esc.
#25
My vote is the 4tec. It is a complete package, and relatively fast for a rtr. As long as you keep the contacts clean on the msc, it should work quite well. If it gets too dirty, it is like having a bad plug, and things overheat and the msc will go poof. To clean it, just use a rubber eraser (onthe end of a pencil or similar equivilent). Should keep things going for a while. Plus it is real cheap for the entire package.
#27
My pick would be the TT-01 you listed above.
#28
Ok, well how fast would this combination for the TT-01 go? http://www2.towerhobbies.com/cgi-bin...?&I=LXCRM8&P=0
What about the 4-Tec?
#29
#30
well after reading all the posts i must say his original post stated that he did not have much money and he was only 14 years old.
my advise is to start mowing lawns and goto ebay and search for a pan car. you can usually find one all set up for under $100
2wd easy to fix
myself i have 2 rs4 touring sedans that are 4x4
they are extremely easy to work on and fun to build as a kit
once you build a kit you know everything about the car
and that makes working on it easier.
i also have a duratrax evader that i set up for both on and off road. so i can have fun in the dirt and jumps and then switch the tires and goto a parking lot and race the on road guys (who hate getting beat by a truck ......
2wd easy to fix
