trx engine tuning
trx engine tuning
I'm new to engine tuning and could use some help from you experts. I recently aquired a used nitro 4-tec with a trx 15 engine. For the life of me I cant get the thing tuned right. Either it hesitates when i squeeze the throttle or it flat dies. Could someone fill me in on what the factory settings for the idle and high speed mixture should be. At least give me a place to start. Maybe some tips on setting both correctly. That would really help. Thanks.
pm kevanb, he seems to know about a good article about tuning.
tuning
ok u can start here get it to run then turn the low speed needle clockwise about 1/8 turn in c if it will go.hold the back tires of the ground and rev it up a couple times.ps will it idle at all let me know ok. do you have aim instant messanger if u do it will be easer for me to help you, let me know.
