standard to metric glow plug size?!
i have a team associated .15 engine. which uses a 5/16 wrench or socket for the glow plug. problem is i live in Japan... they only sell metric!!!!! the metric conversion for 5/16 is 7.938mm. but the guys at the shop i went to today said they don't carry that size.
what can i do other than ordering plugs from America on the internet? will 8mm plugs fit? or will 7mm hold up to compression without stripping out the threads??? is the threaded section actually 7 or 8 mm and the nut top is the only thing different/ in standard.
thanks
~Matt
thanks
~Matt
fear not, 8mm works just fine :P
