Torque help
Torque help
Ive heard alot of people talk about torque on motors but what exactly is it and what does it effect. for instance if you have a higher torque motor in what difference does it make?
Cheers
Cheers
torgue is the amount of strength the motor has for example a ferrari has a high speed engine but put it in a truck and it wont move this is because it has little torque were as a truck motor will launch a truck off the line but not reach that much top speed
same applies to rc, if you have a low torque motor general you gear it lower so that it can take off at a decent speed, with a high torque motor you gear it higher so it has a decent top speed.
hope this helps
hope this helps
cheers lads for the reply
