Brake adjustment
Brake adjustment
i have a HPI nitro RS4 2 it is built driven how do u adjust the brake? it was good now it is off and i can bearly stop the car?
if you still have the plastic brake in there, check it out. It is likely that it has a lot of wear. Replace it with a fiber one.
G-16;
More than likely there has been some wear in the Brake Disc/Shoe assembly. Follow the instructions or visit the HPI website on how to properly adjust. If you are not hard on the brakes, the Plastic Brake Disc can last a long time. If you are MELTING the Disc, time for a better Brake Disc. It all depends on your driving style.
