How to install esc ? (lrp runner)
i have a trinity p2k2pro motor and a lrp runner esc. How would i install the esc? does the motor need the capacitators on it? do i cut the two wires then solder them oN?
thanks
thanks
Solder wires to ESC then solder pos - pos, neg -neg on your motor. You dont need surface mount capacitors on p2k2 pro.
u can run it with a schottky diode though
do i cut those plastic thing off to solder?
ive had no experience with those speedos so i dunno how good the wire is, but it should do. you will probably need longer wires anyway depending on where u place the esc on your car.
red and blue are motor wires, black and red are battery wires.
depending on what connectors you run on your batteries you may need to change those as well to deans or coralli plugs.
just cut the female plugs off and solder peices of wire to the end of those so they reach your motor. alternatively u could just solder the male plugs onto your motor
hope this helps
hope this helps
thanks alot criminal
