Go Back   R/C Tech Forums > General Forums > Rookie Zone
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-15-2006, 11:19 AM   #1
Unhappy oil shocks!!!
I recently got oil shocks and some of the oil slipped out while i was looking at them more closely...
I then began to wonder if there was anthing else i could use? other oils ect...
Is there?
If not then where could i get oil for these at a non rip off price and what density should i get?
I dont want soft but i dont want my car to run like it has no suspension i think they where by topcad what density of oil do they come with? Any1 help?
rcspeedtuner is offline   Reply With Quote
Old 11-15-2006, 02:29 PM   #2
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
Oil weight depends on the track conditions and what you want to do.
What brand of shocks are you using, what kind of car is it, and what are you planning on doing with the vehicle?
Platinum_Racing is offline   Reply With Quote
Old 11-15-2006, 11:30 PM   #3
tt01 on road (carparks, parks ect...) in the uk
Old 11-15-2006, 11:33 PM   #4
p.s. there by carson i think
Old 11-16-2006, 07:03 PM   #5
I use Team Associated Shock Oil in every one of my 30+ R/C cars. It's very consistent and doesn't thicken up in colder weather. It comes in weights from 5 Wt to 100 Wt in increments of 5. It's made from pure silicone, and takes a pretty long time to break down enough to warrant a rebuild in my bashers. I prefer using weights between 20 and 45. I wouldn't use anything higher than 45, and nothing lower than 20 unless it was a really different surface that I was running on. Touring cars react better to thicker oil, so if you have the cash it's a good idea to pickup a bottle of 40, 45, 50, and maybe 55. It's all in personal preferance. To me, that's a bit thick, but you're running touring cars on uneven spaces so you're gonna want something a bit thicker. Different manufacturers go by a different scale when it comes to thickness, so don't buy 35 Wt Associated oil and then replace it with 35 Wt Trinity oil and expect it to be spot on equal, because it ain't gonna happen.
If you're using Tamiya CVA oil dampers then you may look into getting a shock rebuild kit and seeing if it's possible to fit an extra O-Ring inside the shock body. Those shocks use a bladdered cap design with a lower seal system that's housed inside the main body of the shock, not in a lower cartridge like Losi, Associated, and Traxxas (Aluminum only) shocks. Using some Team Associated Green Slime on all rubber O-Rings will prolong the life of the seals and prevent premature leaking. It is a rubber preservation "Slime" that you rub into O-Rings to keep them lubricated and healthy. Dry O-Rings create friction, stiction, and wear. If your shocks were brand new it's possible that you forgot a spacer in between the dual lower O-Rings when you assembled them, or that There is a nice big divot in the upper portion of the shock shaft from a pair of misplaced pliers. When you go to replace the oil in the shock make sure to check out all the components inside the shock, as well as in the lower set of seals.
Good luck!
Old 11-17-2006, 10:27 PM   #6
BuggyKing's Avatar
Well it could be the rings need replacing. They will start leaking after awhile. What car do you have?
- Rob's RC Hobbies Team Driver - Hot Bodies Ve8 - LRP - Thunder Power - JR - Airtronics
BuggyKing is offline   Reply With Quote
Old 11-17-2006, 10:59 PM   #7
TT01
Forum Jump
WTB IRC Shocks Or Losi After Shocks Or LS2 Shocks !jAsOfRaW! Australia Wanted to Buy 0 01-25-2008 01:12 AM
shocks harddrive Electric Off-Road 1 02-01-2006 01:10 PM
JRXS SHOCKS OR TRF SHOCKS RED-LINE M03 Electric On-Road 23 10-18-2005 05:24 AM
wtb: 1/8 rear buggy shocks or t-maxx size shocks arawak420 R/C Items: Wanted to Buy 0 05-23-2005 06:05 PM
Trade: B4 Shocks for Bk2 shocks Driver1 R/C Items: For Sale/Trade 0 10-19-2004 10:02 AM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
