handling...
handling...
hi just wandering what would be the best handling hop up i can get for my tt01?
(i got springs)
(i got radials too)
(i got springs)
(i got radials too)
Oil filled shocks(not sure if it comes wiht them stock)
-Tires(radials are typically not great if your talking threads) Typically the best tires are slicks by takeoff,sorex,rp,ect....
-practice
-adjustable suspension set, i beleive that car come stock with fixed toe and camber...
-practice
yea it does lol any tips on camber and toe angles?
plus arent radials ok in uk especially in the winter cuz the ground is probly below freezing in winter but boiling hot in the summer.
if your running at outdoor temps below 15C then it dont matter there are no really good tires for that type of cool racing...
Radials with treads look kool but dont offer any great traction, stick with low compound tires like in the 20-24C ranges they are the softest you can get and work best on kooler track temps
Camber start at 1-2 degrees front and rear. AGain for bashing you have nothing to gauge your performance on unless you setup a track to time your self on.
