Go Back   R/C Tech Forums > General Forums > Rookie Zone
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-30-2006, 10:20 AM   #1
Angry STEERING problems!! ie no steering
well i have had this car 3-4 days maybe less and well it was supposed to be a tank yet mine broke!!!
basically i hit a curb side on and from their on it lost all steering??
as i didnt build it i have no idea about it (TL01) and really need help.
When you turn the steering on the controller the cars electrics still make a noise like its turning. but the wheels dont turn. if i push the wheels and steering rack and do the controller it does turn a little (bare in mind i started to strip the car down but my eyesight means looking at the manual and little parts is not the best move as i will loose things so the car is still whole)
Whats the problem?? i know youll say you dont know without looking at it but could it be an easy fix for someone who knows about them and more to the point could it be expensive???
tha car stills runs back and forth but no steering??
please help
creamsodauk is offline   Reply With Quote
Old 06-30-2006, 11:01 AM   #2
Moderator
MarkA's Avatar
Possible causes:
Bent tie-rod binding the steering.
Broken Servo Saver
Broken Servo Gears
None are really that expensive and in the case of the last one, you can buy a whole new "standard" servo for @$12 instead of messing with the gears.
When the car is on and you turn the wheel, does the part attached directy to the servo move at all?
MarkA is offline   Reply With Quote
Old 06-30-2006, 11:02 AM   #3
Joel Lagace's Avatar
Sounds like you busted the servo. Go to your local hobby shop and pick up a new servo. Cheap ones like the futaba 3003 are about $15 and you could spend up to 150$ on a race worthy servo..
Servos are pretty tuff but if you hit curbs you will brake them. For about 30-40$ you can get metal gear servos that will take a little more of that abuse..
Try your best not to hit curbs though
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-30-2006, 05:31 PM   #4
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
yeah sounds like u got a busted servo.....get anew servo and open up the old 1......its fun lol
ProudSavageOwnr is offline   Reply With Quote
Old 06-30-2006, 05:35 PM   #5
Talking
i laugh at myslef for this but my older more hands on brother took a look and saw that some sort of arm thingy had come off the over arm thing so wen one moved the over didnt!!!!
so a easy 2 min job and only 2 screws wer removed8)
but i learnt my lesson and will stick to car parks etc not a narrow cambered road!!!
cheers and shame on me for crashing it!!!
Old 06-30-2006, 09:17 PM   #6
yeah its hard to tell without a pik....
Forum Jump
steering problems mhearn Nitro Off-Road 1 06-30-2007 07:41 PM
problems with steering ash1 Chat Lounge 1 06-23-2007 05:26 PM
rc18t steering problems kgonder1969 Rookie Zone 5 02-21-2006 03:47 AM
Steering Problems riceboy89 Electric Off-Road 4 11-27-2004 03:16 PM
Steering problems on my G4 spotinc Nitro On-Road 1 06-13-2004 08:54 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
