Go Back  R/C Tech Forums > General Forums > Rookie Zone
Engine flood problems >
Old 04-26-2006, 08:00 AM
Unhappy Engine flood problems
hi, i have a kyosho GP SPider MK2 with a GS11r Engine, my engine was flooded but i removed the glow plug and drained out the fuel, but when i replace my glow plig, the pull start is still stiff and hard to pull, when i remove the glow plug, the pull start is easy to pull.
I am a beginner and any hep would be much appreciated.
Thank You
khany1 is offline
Old 04-26-2006, 04:26 PM
Loosen up the glow plug about a turn and try to crank it. This will minimize the compression and will be a little easier to pull.
crash21 is offline
Old 04-27-2006, 09:25 AM
Unhappy
hi, i turned the plug half turn and tried to start it, but i wouldn't, i could feel air coming out the top of the engine when i pulled the pull start, at one point, i removed the air filter, and the caboretor was full of fuel. so i unflooded again by turning it upside down, and tried starting again. still no luck
ps, the needle is set to 2 turns from the closed position
Cheers
khany1 is offline
Old 04-28-2006, 05:52 PM
Sounds like u may have a faulty carburetor. But Kyosho generally dont have these sorts of problems. Try heating the cylinder up to ease with compression with a heat gun or similar, but be careful not to burn any plastics. Also check your glow starter is working, and your glow plug hasn't been damaged from previous floodings. Also make sure u don't put too much fuel in when priming, and by the way are you priming using the pull start or a primer on the fuel tank.
theBUZZ is offline
Old 04-30-2006, 01:59 AM
ProudSavageOwnr's Avatar
dude i have a gp spider mk II and the gs11r is ancient history......the starters in those things end up wearing out and start leaking fuel out of the oneway ... i had the same problem and from all the times i tried to start it i just ditch the motor and bought a force .12.....this thing RIPPED man.......i REALY suggest u buy a force .12 there around 60 bucks and are realy worth it dude.....even better..ditch the car altogether ... i havnt been able to find parts for it for around 4 years now and mines totally stuffed like the 2speed and stuff
ProudSavageOwnr is offline
Old 05-02-2006, 06:45 PM
40%
40%'s Avatar
1. check your glow plug if it's working
2. Invest in a starter box or a hand held starter if you can
be ready to invest in a set of tools....The pullstarter on the GS is quite fragile.
40% is offline
