Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-08-2006, 07:16 PM   #1
bvoltz's Avatar
Trader Rating: 44 (100%+)
Default Motor questions...
How offen should springs be changed?
What is a good dyno?
Now for the fun one....
How much longer until brushless take over and all this equipment for brush motors is not needed...
bvoltz is offline   Reply With Quote
Old 03-10-2006, 12:00 PM   #2
bvoltz's Avatar
Anyone???
Old 03-10-2006, 02:46 PM   #3
Johnathan's Avatar
the brushes are what wear out, not neccisarily the springs. sure, if the spring is broken, replace it! ive used a motor for years with the same spring set.
hope it helped!
Johnathan is offline   Reply With Quote
Old 03-10-2006, 03:56 PM   #4
westcoast_racer's Avatar
Send a message via AIM to westcoast_racer Send a message via Yahoo to westcoast_racer
over time, the spring will loose is tension due to heat and normal motor usage. I have never used a spring dyno...a sonic fiddlestick is all i think is necessary...you mainly want both springs to have the same tension.
For changing springs...its up to you. They are cheap, so replacing them is cake
westcoast_racer is offline   Reply With Quote
3 questions about Motor,batterie and motor lathe Rasmus TbEvo IV Electric On-Road 8 02-18-2006 12:30 PM
Motor Questions SPC Racer Electric On-Road 1 07-30-2005 10:48 PM
Motor questions RoGuE_BULL Rookie Zone 3 02-12-2005 08:36 AM
Motor Questions???? SPC Racer Electric On-Road 7 01-13-2005 08:25 PM
motor questions stoopidbstrd Electric On-Road 12 03-10-2003 10:19 PM
