Help a moron with a JR Xr3i
I can't believe this damn thing. Too many adjustments. Anybody know what I should set this thing to? It's a JR XR3i Radio with a GTB 5.5 in an xxx-4
Can't stand radios. Or maybe I'm an idiot. Anyhow, If I list the parameters, can someone tell me what to set them at?
exp THB, it's at 20%, when I pull the trigger, it says ext THF and it's set to LN?
exp ST is 100%
epa TH R/B is set to 125
epa L/F (when I pull the trigger) is set to 125
mix THB is 125%
mix STR is 0%
trim STS is 0
trim THS L/F is 15
TDB is 0%
trim THC is 0
Any ideas what all this stuff is? Still an idiot, still a noob.
exp ST is 100%
mix THB is 125%
mix STR is 0%
trim STS is 0
trim THS L/F is 15
TDB is 0%
trim THC is 0
I will do my best
I will do my best to explain. I have a JR radio.
EXP is for exponential. set this to LN (linear) on both the brake THB and the Throttle THF. pull the trigger and hit decrease.
exp ST is 100%
Set this to LN Linear as well. I run about -50% to help take out sensitivity of my steering but I would start with LN.
This is the Brake End Point Adjustment. Smaller number less brake.
I would leave this here. if this is an electric, on a gas carb adjust it to the point where the carb is wide open.
mix THB is 125%
Set the Mix to 0%
mix STR is 0%
Set this to 0%
trim STS is 0
Set this to 0%
trim THS L/F is 15
Set this to 0%
TDB is 0%
Set this to 0%
trim THC is 0
Set this to 0%
Try this link to JR and download the manual. ----Take Care Billy
JRX3 I Manual
exp ST is 100%
mix THB is 125%
Set the Mix to 0%
mix STR is 0%
Set this to 0%
trim STS is 0
Set this to 0%
trim THS L/F is 15
Set this to 0%
TDB is 0%
Set this to 0%
trim THC is 0
Set this to 0%
JRX3 I Manual
