Gear pitch
Gear pitch
What pitch are the teeth on nitro clutch bells?
Jerry
Jerry
it depends on the car/truck. tell us what your car/truck is, or look at the manufacturers web, or call them.
gear pitch
I thouht that most nitro cars are 32 pitch on the bell.electric cars run 64 and higher pitch.Am I correct?
Electrics usually run 48 and 64 pitch (E-maxx uses 32 pitch) because the bigger the teeth are, the stronger the gear is and less precise. Nitros need the extra gear strength and use 32 pitch generally.
thank you .that is what I was thinking.Forgot about the 48
