Tamiya Body Set for TRF201X, GAZOO TRD 86, Avante 2001 Egress & More
Tamiya 1/10 GAZOO Racing TRD 86 Body Set 190mm #51541
This is a clear polycarbonate body parts set of the GAZOO Racing TRD 86 race car. It is made out of 1mm thick polycarbonate. The set includes masking seals for the windows and a sticker set to replicate the Gazoo Racing Team livery.
Click here for more!
Tamiya 1/10 Avante 2001 Egress Chassis Body Set #84372
This is the Avante 2001 Body Parts set originally released in 1990. It's a limited release and it is designed to fit the re-release of the RC Egress off-road racer (58583).
Tamiya 1/10 TRF201X Lightweight Body Set 0.6mm XR/XM #84374
This is a new lightweight version of the body designed for use on the TRF201 chassis fitted with the racing-spec XR and XM sets.
Tamiya Racing Wing Set 2 Hard Type 1mm #84371
This wing set is a reinforced version of Item 54494 Racing Wing Set 2. It includes two different shapes of wing; curved and straight - which can be used to adjust the downforce of your RC car model. The wings are made from 1.0mm thickness polycarbonate, as opposed to the 0.7mm thickness of those in Item 54494.
he wings are compatible with any Tamiya touring or sports car body that has space available to make wing attachment holes. Whether it is to add a stylish look to your vehicle, or if you want to raise your down-force on a tough track, this item is for you!
Tamiya TT02 3x18mm Step Screw 2pcs - Low Friction #54550
These are low-friction step screws for use on the Tamiya TT-02 and TT-02B car chassis platform. These 3x18mm step screws replace those used as standard in the TT-02 chassis steering arms. The low-friction finish makes for more precise function. The hex heads on these screws match those seen in other option parts. Contains 3x18mm Step Screws x2 (enough to complete a single TT-02 chassis; note that theTT-02B chassis requires 4 screws.) A hex wrench is included to attach the screws.
