KO PROPO EX-1 ASF 2.4GHz Ver.3 KIY
KO PROPO EX-1 ASF 2.4GHz Ver.3 KIY #80537
The Ver.3 EX-1 KIY uses the same Ver.2 software in the Master Unit, but includes the redesigned ‘Expert Grip Unit’. This grip unit has updated grip pads that provide a different fulcrum point on the handle and an updated trigger with a redesigned trigger stroke.
The KO PROPO Kustomize It Yourself (K.I.Y.) is an interchangeable transmitter that brings simplicity to customizing and upgrading within a modular system. The transmitter is composed of 3 modular units: Steering, Throttle and Master units. The three separate modular units can be easily put together, no screws required. Just push the safety lock of the joint, pull the lever and pull or push to insert or remove the modular unit. It’ s that simple! You can use the K.I.Y. to unlock your next system and bring more enjoyment to your hobby.
As optional parts and items become available you can add to your existing system without worrying about purchasing an entirely new transmitter for you to use. One of the many bonuses of the KIY concept.
Click HERE for more details!
