G.T. Power LED Light System, Tire Warmer Stocked!
G.T. Power RC Power Multi Distributor #GTP-35
The G.T. Power RC 4-Output Power Bus distributes power from a power supply to up to five electrical devices.
Item no.: GTP-35
G.T. Power RC Police Car Lighting System GTP-64
Item no.: GTP-64
G.T. Power RC Car Controlled / Simulated / Flashing Lighting GTP-53
This is the one of the most advanced item in RC market. The flashing mode, simulated turn signal, backward light, brake light can bring you real driving fun. It is radio controlled, easy to set up and operate, so it is the most of RC car amateurs' best choice. To reach your ideal effect, please read the instruction manual carefully. We believe your car will be a beautiful scene on the track with this product.
• Simulated linkage makes your car more dynamic.
• Equipped with electronic switch can turn on/off the light set optionally.
• 8 available light set interfaces.
• 6 kinds of flashing modes (such as flashing, breathing lamp, Cruise lamp and al ways bright lamp)
• The obverse and reverse setting of the channel makes the installment more convenient, and suitable for supporting the use of different remote control receivers.
Item no.: GTP-53
G.T. Power RC Tire Warmer with Temperature Controller GTP-21
This is G.T. Power RC Tire Warmer with Temperature Controller.
• Quick Adjustable Voltage
• Small, Lightweight
• Relay switch operation
Item no.: GTP-21
G.T. Power Mini-Z RC Car LED light system GTP-57
Item no.: GTP-57
G.T. Power Lighting System for 1/5 1/8 Off-Road RC Car GTP-69
This lighting system use intelligent MUC control and have two sets of super bright lights groups. It's easy to set up and operate.
Item no.: GTP-69
G.T. Power RC Motor Sensor (HALL) Tester GTP-70
This product equipped with the power supply, use LED to display the test condition; small volume, convenient to carry. It can well to test the quality of the motor hall SENSOR. In order to facilitate for your using, please read the manual carefully.
This product is only applicable to test the SENSOR of the sensored motor.
Item no.: GTP-70
G.T. Power Digital Battery Capacity Checker / Tester for LiPo LiFe Li-Ion NiMH NiCd GTP-51
The GT Power Digital Battery Capacity Checker can be used to check the battery voltage of Lithium batteries including Lipo, LiFe, Li-Ion, as well as NiMH and NiCd batteries. The checker will measure the voltage of both individual cells and full battery voltage, and can also indicate the highest voltage cell, lowest voltage cell and difference in between, as well as display the percentage of battery capacity remaining.
Item no.: GTP-51
Item no.: GTP-35
Item no.: GTP-64
Item no.: GTP-53
Item no.: GTP-21
Item no.: GTP-57
Item no.: GTP-69
Item no.: GTP-70
Item no.: GTP-51
