Axial Wraith 1/10 Scale Electric 4WD Rock Racer Kit (#AX90020)
http://www.youtube.com/watch?feature...&v=9KhQq6YoEGY
The Axial Wraith™ changes the game with its impressive 1:1 scale looks, high-speed monster truck "bashability," and technical "crawl" capabilities. The Wraith™ is the most versatile vehicle satisfying the needs of a wide range of enthusiasts! The realistic looks, drivability and ready-to-run ease make this vehicle the perfect blank canvas for the enthusiast looking for a vehicle to build upon. The Wraith™ can go in so many directions; desert sand, mountain trail runner, rock racer, mud bogger and any form of backyard bashing that can be dreamed up!
Features:
Chassis: Full tube composite construction with composite skid plate
Drive: Four wheel shaft with steel universal joint axles and splinted plastic slider that uses a screw shaft for a more positive lock to the output shaft
Transmission: Steel output gears and slipper clutch equipped, upgradable for three function Dig feature
Differentials: Locked type with easy access for rebuilding and maintenance
Suspension: Four link
Shocks: Oil-filed with silicone diaphragms and bushings and 3.5mm titanium nitride coated shafts, purple (soft) springs
Cockpit: Console and gauge detail with licensed Corbeau LG1 race seats
Battery Tray: Sized for 6-cell 7.2V standard stick packs or 2S LiPo pack up to 1.8" (47mm) wide, 5.9" (150mm) long, 1.1" (28mm) high
Tires: 2.2" (56mm) diameter Ripsaw R35 soft compound, 5.5" (140mm) diameter with foam inserts
Wheels: Raceline Renegade 8-spoke 2.2" black in color, 12mm hex mount
Light Buckets: 14 total, 7 different styles hold 3mm and 5mm lights (LEDs not included), the Simple LED Controller add four lights in the front and two in the rear, the Night Vision Setup adds more lights and a control system
Body: Clear polycarbonate panels
Click here to learn more: AX90020
Features:
