Go Back   R/C Tech Forums > Commercial/Retail Forums > rcMart.com Mega Online R/C Marketplace
Old 03-04-2010, 10:45 PM   #1
Shop Owner
rcmart's Avatar
Trader Rating: 1 (57%+)
Default iMAX QUATTRO B6 Charger and PC Connection Kit restock
*Click the image to buy
The iMAX QUATTRO B6 Professional Balance Charger / Discharger has just restock @ rcMart.com
Tired of charging one battery at a time? Try iMAX Quattro B6! At last, a charger where you can charge 4 Battery packs at the same time no matter what battery type you may have.
This charger allows you to plug 4 batteries into one charger simultaneously, and it will intelligently and automatically charge all 4 of them at once to their maximum capacity. To top of it, the batteries being charged do not even need to have the same configuration. You can connect different chemistry(Ni-MH/Ni-CD/LiPo/LiFe)batteries into any of the charging ports. No more staying up late for charging batteries.
Specifications:
Input: DC 11 to 15V
Power source: 12V DC (car battery)/ AC mains PSU (>200Watts0
Charger power: 50Watts, current is regulated accordingly.
Discharger power: 5 watts, current is regulated accordingly
Cell count: 1-15 Nicd/NiMH cells; 1-6S LiPo/Lilon/LiFe cells; 1-10 Lead-Acide cells (2V to 20V)
Current drain for balancing Lithoum: 300mA
Charge termination: automatic, negative delta peak method for NiCd/NiMh; and automatic, voltage-dependent, CC-CV process
Dimensions: 225.4 x 158.6 x 62.4mm
Net weight: 1.09kg
High Performance Micro Processor
iMax Quattro B6 Pro Charger & Balancer is a rapid charger with a high performance microprocessor.
Individual Voltage Balancer
Quattro B6 has an individual-cell-voltage balancer inside. This does not require any extra balancer when charging Lithium batteries (Lilo/LiPo-LiFe) for cell voltage balancing
Suitable for various types of Lithium batteries
Quattro B6 can accept three types of Lithium batteries – Lilo, LiPo and LiFe. They have different characteristic by their chemistry. You can select any one of them that you are going to process before the job. For their specifications, refer Warning and safety notes section.
Maximum safety
The automatic charge termination program works on the principle of the Delta-peak voltage detection. Auto-charge current limit: When charging NiCd or NiMH at AUTO current mode, you can set the upper limit of charge current to avoid from high current charging.
Capacity Limit: If the charging capacity exceeds the limit the process will be terminated automatically when you set the maximum value.
Processing time limit
You can also restrain the maximum process time to prevent from any possible defect.
Data store / load
For users convenience it can store 5 data of different batteries per charger (20 in total)
You can establish the data contains program setting of the battery to charge or discharge continually.
These data can be called out at any time you need and the process can be executed without program setting.
High-power and high-performance circuit
Quattro B6 employs the circuit that has maximum output power of 200W. As a result it can charge up to 15 cells NiCd / NiMH 6 cells lithium with max current of 5A and 8 series of Lithium batteries with maximum current of 7.0A. Furthermore the cooling system is so efficient that can hold such a power without any trouble of running the CPU or the operating program.
Optimized User Interface
Quattro B6 has an AUTO function that sets the feeding current automatically. It can prevent the over-charging. Program in the unit are controlled with mutual links and communication for every possible error for maximum safety.
Balancing individual cells battery discharging
Quattro B6 also can monitor and balance individual cells of the Lithium battery pack during the discharge process. If the voltage of any one cell varies abnormally, the process will be stopped with the error message.
Lithium battery Fast and Storage mode
You can charge Lithium battery for special purpose. Fast charge reduces the charging time of Lithium battery and Storage mode controls the final voltage of the battery to be suit for long time storage.
Temperature threshold (Optional)
The temperature of the battery on charging will be rise by its internal chemical reaction. If you set the limit of temperature the process will be expired forcibly when the limit has reached.
Input power monitoring
To protect the car battery using as input power from being damaged the voltage of it always monitored. If it drops below the lower limit the process will be ended automatically.
Cyclic charging / discharging
Perform 1 to 5 cycles of charge / discharge or discharge / charge continually for battery refreshing and balancing.
Includes:
1 x charger
1 x pair alligator clips for Pb battery
1 x alligator to bullet connector cable
1 x JST to bullet connector cable
1 x Futaba to bullet connector cable
1 x Tamiya to bullet connector cable
1 x bullet connector with wire
1 x TP/FP adaptor
1 x XH adaptor
1 x instruction manual
Where to buy?
http://www.rcmart.com/catalog/rc-cha...p-p-30354.html
IMAX (#SK-SW00P100) Software Kit
Where to buy:
http://www.rcmart.com/catalog/rc-con...?cPath=52_1433
Source: iMAX
Your RC on-line Shopping mall
Fast worldwide delivery & low shipping rates
URL: www.rcMart.com
RSS: rss.rcmart.com
FB:www.facebook.com/rcmart
Twitter: twitter.com/#!/rcmart
Google+: plus.google.com/u/0/?tab=XX#106357714268726518339/posts
rcmart is offline   Reply With Quote
SEO by vBSEO 3.5.0
