*Click the image to buy
The Tamiya (#92206) 1:10 TB-03D EP Chassis Kit w/Upgrade Pack is restocked on the rcMart's shelf. Due to the popularity of this chassis, the stock is very limited so be quick to get one before it has been sold out again!
Based on the previously released TB-03D Drift Spec Chassis Kit (Item 58420), this 4WD TB-03 chassis machine features the same excellent direct drive feeling. This kit features the many drift specifications such as Super Driftech resin tires, outboard type suspension, short reversible suspension arms, soft spring damped shocks, and dedicated suspension mounts, for exciting drifting. Also included is a special Upgrade Parts Set full of Option Parts to add further value to your drift machine.
TB-03D Drift Spec Chassis Kit x 1pc.
Over 15,000 yen worth of Option Parts are included in the Upgrade Parts Set.
Motor, ESC, 2-Channel R/C system, battery pack and charger separately required.
RC 1:10, Car, Electric-Powered, On Road
Specification:
Vehicle:
Drive: 4WD
Length: 363mm
Wheelbase: 257mm
Tread Front and Rear: 165mm
Gear Ratio: 7.09: 1
Tires: F/R Width/Diameter 24mm/63m
Include:
TB-03D Chassis
Instruction
Optional parts included:
TB-02 Drive Shaft
TB-03 Aluminum Universal Propeller Shaft
TB-03 Aluminum Propeller Joint Set (Rear)
TB-03 Front One-way Unit
TB-03 Aluminum Heat Sink
TB-03D Direct Coupling
TB-03D Aluminum Bumper Support
TB-03D Aluminum Rear Upright (1 degree)
Where to buy?
http://www.rcmart.com/catalog/rc-tam...k-p-29390.html
