*Click the image to buy
SuSuMu Power new designed Li-Po Battery Safe Guard Charging Bag is now available @ rcMart.com. There are 2 sizes available for these Li-Po battery charging bag, small size (#SSM-29797) - 215mm x 180mm and large size (#SSM-29798) - 300mm x 230mm.
Description:
#The LIPO SAFE is a hi-tech bag made of Fireproof Fiberglass materials that can contain a lithium polymer battery fire or charging mishap. It is easy to use. Just place your lithium polymer battery into the LIPO SAFE and extend the charging wires through the top flap. Charge the lipo batteries when they are in the LIPO SAFE and you shall gain peace of mind and greater safety. In case of a lithium polymer battery charging mishap, the LIPO SAFE is fire-resistant, and can mitigate the ferocity of the LiPoly blaze inside and release the smoke out of the LIPO SAFE.
#The LIPO SAFE is sealed with a thick, industrial strength, Velcro flap. The current LIPO SAFE is designed to handle a lithium polymer battery mishap from 1 to 3 lipoly cells
Feature:
For: Lipo Battery
Material: Fiberglass and Fireproof Plastic
Specification:
Size: Approx. (Small) L 215mm x W 180mm
Size: Approx. (Large) L 300mm x W 230mm
Caution:
#Never leave charging battery unattended.
#Always ensure the battery is on a non-inflammable surface
#Eusure flap is sealed while charging
#The LIPO-SAFE is intended to reduce the chance of damage in the event of a LiPO fire.
The SuSuMu Power Li-Po Battery Safe Guard Charging Bag will be a prefect match with the SuSuMu Power Li-Po 3200mAh battery. Please have a look at the details of the SuSuMu Power Li-Po 3200mAh battery below:
The SuSuMu Power Li-Po 3200mAh battery is covered by a stylish look graphite hard case and only weight 210g. The bottom of the case contains 2 rows of bumps provide perfect fittment on wide range of chassis. This racing battery pack is especially design for 1:10 or M-Chassis race.
Specifications:
- Discharge rate: 20C
- Capacity:3200mAh
- Voltage:7.4v
- Length: approx. 138mm
- Width: approx. 47.5mm
- Height: approx. 21.5mm
- Net weight: 210g
Where to buy the SuSuMu Power products?
http://www.rcmart.com/catalog/advanc...ords=susumu+29
