My DIY Quad X - Fly with 2 pack of RC car 7.4V batt.
My home have many of car racing battery that i used with my RC car racing.
Now i can use these battery pack with my X copter.
I wiring 2 pack of 2S 7.4V battery to 4S 14.8V,
yes it can fly and get long fly time about 20 minute.
2 pack of rc car race battery (=14.8V), it easy to install to my x copter frame.
My x copter installed with 2 pack battery and DVR A118 camera, the total weight is 1.6KG.
when fly with this 6800maH 70C 14.8V battery, my X copter can fly continuous 22 minute.
but for longer life of battery, i fly only 20 minute.
my x copter info updated on Sep 8, 2014.
Hi there, do you have a parts list or instruction on how to make this diy quad? I am very interested because i have some 4s battery for my rc car that i would like to use. thank you.
Now i build new frame S500 that better for install 4S battery. see below
The important things for multi copter that will use 4S battery are ...
+ Motor must support 4S battery (or up)
+ Propeller must suite for 4S battery
+ ESC must support 4S battery (or up), and support max cuurent of motor use, and i always use ESC that have firmware 'SimonK'
YouTube Video => http://www.youtube.com/watch?v=K4jfgjdn7ws
+ YouTube Video | |
with my new frame S500 that fly in this video. i use ...
Frame : S500
Motor : EMAX MT2213 935KV
Propeller : EMAX 1045
ESC : for multicopter with SimonK firmware, 30Amp, 2-4S Li-Po
but i will upgrade motor and propeller for suite with my total weight soon.
So, if you want a better solution, you should wait for new solution
you can see my update things at facebook page http://m-rotor.com (this will redirect to my facebook page)
Do you have a parts list of the one you are building?
many items that i used are OEM china products, some don't have a part number / model number
you should try to search it at ebay.
Frame : S500
Motor : 4 X EMAX MT2213 935KV
Propeller : 2 x EMAX 1045 CW , 2 X EMAX 1045 CCW
ESC : 4 x ESC for multicopter with SimonK firmware, 30Amp, 2-4S Li-Po
BEC : switching 5V 3A
Flight control : i build it myself, but you can use APM 2.5.2 or 2.6 instead
GPS module : Ublox Neo-6M with compass
battery sensor : Power module for APM, BEC 5.3V / volt sensor / current sensor
many details about FPV, OSD, Radio Telemetry devices
view its at my FB page http://facebook.com/9rotor
+ YouTube Video | |
Thank you for the information. By the way, do you still sell the backlight kit for the MT4 or know where i can purchase one?
Thanks sir
about MT4-backlight kit, i still can't buy some parts since several months ago until now. So, i can't production it again.
btw, here is my attempt at building my first quad, your input would be greatly appreciated.
http://www.rcgroups.com/forums/showthread.php?t=2322912
Okay, here is what I have so far, please give me your inputs:
1. Flight controller - OpenPilot CC3D http://www.banggood.com/OpenPilot-CC...-p-937044.html
$14.99
2. Frame - Diatone Q450 http://www.banggood.com/Diatone-Q450...-p-942100.html
$13.99
Diatone Q450 V4 Ghost Edition http://www.banggood.com/Diatone-Q450...-p-957593.html
$19.60
HJ 450 http://www.banggood.com/Wholesale-HJ...t-p-56959.html
$14.25
3. Battery - HobbyKing 4S 5000mAh 4S1P 20C http://www.hobbyking.com/hobbyking/s...case_Pack.html
SMC 4S 5000mAh 50C http://www.smc-racing.net/index.php?...product_id=175
Already have these so no cost.
4. Prop - I have no idea where to start with this.....
5. ESC - Not sure about this either, yet..
6. Radio - Turnigy 9x 9CH Transmitter http://www.hobbyking.com/hobbyking/s...Firmware_.html
$59.99
FlySky FS-TH9XB http://www.banggood.com/Wholesale-Fl...2-p-47904.html
$89.55
First step to build your DIY, you should define purpose of your DIY drone.
it will fly for ?
for fun , for fly acrobatic ,
for fly simple video record, for fly high quality video record,
for fly FPV fun, for fly FPV+OSD+high quality video record,
or ...
one drone can't do all purpose, so you should define it purpose at first.
then select flight control board that suite with it purpose,
then select frame for it purpose,
then select option devices for it purpose,
then select battery for it purpose,
then select motor + propeller that can support total weight and support battery voltage,
then select ESC that can support motor current and battery voltage.
warning about transmitter & receiver.
it 2.4G technology very important for sure and range of control.
many of low cost TX/RX use poor 2.4G technology, only few low cost brands that have good 2.4G technology.
it will fly for ?
or ...
