NORVEL engines and parts are back in production
Norvel engines and parts now back in production. The exclusive US distributor's email is [email protected]
Here is a price list. Prices for Norvel engines 0.15, 0.25, and 0.40 will be posted later
Norvel Big Mig 0.049 CL $60.95
Norvel Big Mig 0.049 RC $63.95
Norvel Big Mig 0.061CL $69.95
Norvel Big Mig 0.061 RC $72.95
Norvel Big Mig 0.074 RC $84.95
Crankcase 06 100108-01 $22.99
Crankcase 07 100108-02 $23.99
Crankshaft 06 100110-01 $18.95
Crankshaft 07 100256-01 $19.95
Cylider/Piston assembly Big Mig 04 100406 $24.95
Cylider/Piston assembly Big Mig 06 100402 $27.95
Cylider/Piston assembly Big Mig 07 100407 $29.95
Cylider/Piston assembly Big Mig 15 301004-03 $35.95
Cylider/Piston assembly AME 06 (limited stock) 100401 $37.95
Wristpin 04-06 100103-03 $3.95
Wristpin 07 110103-01 $3.95
Connecting rod 06 100113 $7.95
Connecting rod 07 100113 $8.95
Head wrench 04-07 230131 $3.95
Glow plug 04-06 110138 $7.95
Glow plug 07 110158 $8.45
Head adaptor for std. glo plug 04-06 100148 $4.29
Head adaptor for std. glo plug 07 120131 $4.39
Cover plate 04-06 100100 $7.95
Cover plate with a pressure fitting 06 100100(f) $12.95
Cover plate O-ring 04-06 300209 $3.29
Cover plate O-ring 07 100209-06 $3.29
Spring starter 102105 $6.00
Cylinder head gasket 04 (2) 100112-01 $3.29
Cylinder head gasket 06 (2) 100112-01 $3.29
Cylinder head gasket 07 (2) 100116-01 $3.49
Glow head gasket 04-06 (3) 100117 $2.99
Glow head gasket 07 (3) 101717 $2.99
Needle valve screw 049-25 120114 $8.95
Prop screw 04-06 100137 $1.95
Prop screw 07 100337 $2.50
Prop spinner 04 100102 $4.95
Prop spinner 06 100102 $4.95
Prop spinner 07 100302 $4.95
Prop spinner & screw set 100153 $6.49
Prop hub 04-06 100124 $5.95
Prop hub 07 100124-01 $5.95
Drive gasket 04-06 100136 $1.99
Drive gasket 07 100136-2 $1.99
High performance Venturi assembly (without needle) 110159RC $14.95
Needle valve sub-assembly RC 04-07 100159RC $19.95
Throttle lever 04-15 100202 $4.95
Throttle lever stop spring 04-07 100204 $2.89
Throttle lever stop screw 04-07 100205 $2.89
Venturi O-ring 04-07 100209-05 $2.89
Veturi nut 07 100281 $2.89
Venturi screw 100291 $2.89
Cylinder head screw 07 (qty 4) 100127 $4.49
Muffler 06 101003-05 $9.95
Muffler pressure spring 04-06 110120 $2.99
Muffler assembly 07 110157 $22.95
Carburator assembly 04-07 (without needle) 101159RC $22.95
Head 04 110131 $4.95
Head 06 110131 $4.95
Head 07 120131 $4.95
Wire net 04-07 100122 $3.49
Fuel tank mount 06 102100 $13.95
