flyzone cessna 182 RTF
hey guys , i just bought one , and it came with one battery, i want to go lipo and i have no clue what size lipo will fit in there and what ESC to use with it, can anyone point me in teh right direction
anyone ????
well if its the red one with the 380 brushed motor the stock one is 15amp and rated up to 7cell 8.4V so I would look for a brushed esc that as a lipo cut off like electrifly C-25 mini and use a 1500- 1800 mah 2s battery but you will lose power because less voltage. A 3s would most likely toast the motor. unless you go brushless with an 400 size outrunner than you would only benifit all the way around. hope this helps.
