ok i have 2 planes Nexstar select .46 and a Hobbico Avistar. My question is this Can i take the o.s .46 from my nexstar select and put it in my avistar.
this ist the engine that tower recommends for my avistar
http://www3.towerhobbies.com/cgi-bin...?&I=LXFMD5&P=M
and this is the engine in the select.
Engine: Pre-installed O.S. Max .46FXi (7.5cc) with High-Speed
Needle Valve extender/limiter that limits the movement of the
High-Speed Needle to prevent engine from being run too lean.
Engine is mounted on IsoSmooth Mount to isolate airframe and
radio gear from damaging vibration
on my avistar since its a slightly smaller plane I would change Props to the avistar Prop Correct?
